Manual Steering Gear W/ Pitman Arm
Private parties only. No eBay/Craigslist listings.
Mach428
Post by Mach428 »
I have a perfect manual steering gear with pitman arm that I removed from my 69-F250 to add power steering. My truck is an original 27,000 mile show vehicle that my dad bought new, so it is not worn or beat up. It does need the pitman arm nut as I used that on the PS box.
Price is $50 plus shipping from Florida
Power By Ford 70 F250 4x4
Re: Manual Steering Gear W/ Pitman Arm
Post by Power By Ford 70 F250 4x4 »
I need one for my 70 4x4 does the box mount to the frame and the shaft go through a hole in the frame and the pitman arm is on the opposite side?If so I will take it.Could you show a picture?
Mach428
Post by Mach428 »
I'm pretty sure this will not work on a 4X4. The shaft mounting is nothing like you've described. Sorry
