Does anyone have a part number for this? We had to check our rear brakes, and in so doing the axle seal has to be replaced. It's a 1971 with dual rear wheels. My hubby has gone to the parts store twice and they have given him the wrong seal each time. I went to the schematics section here for the rear axle and printed it off for him, which he took to the parts store, but they couldn't cross-reference the number with anything.
We have a Napa store as well, but they were useless...asked if a F350 was a Ford, and then couldn't find any axle seals at all for it. You pretty much have to have a part number on hand to get anything from this Napa store. Also I have googled for hours today trying to find an answer but am not having any luck. I've found some that might be it, but I'd rather have a part number straight from one of you guys if I could.
TIA,
Cindy
Dana 70B Rear Driver's Side Axle Seal
- LuvMyScamper
Cindy
1971 Ford F350 Scamper - 390/C6
2004 Jeep TJ - Lifted, locked and trail ready
2015 Hyundai Santa Fe - Grocery getter/gas miser
- 1972hiboy
Re: Dana 70B Rear Driver's Side Axle Seal
Cindy, Gave a call to my local jobber, Wasnt sure if you were looking for the inner oil seal that goes in the back side of the hub or the outter flange gasket that has 8 holes in it. So I got numbers for both.
The inner hub seal that you have to press out and press the new one in is a NATIONAL 9864S
The outter axle flange gasket is a FELPRO 55328
Also take into consideration not all seals are made the same. The national may look different than the CR or other brands but the sealling surface is still where it needs to be. fyi. Good luck
Rich
Dont eat yellow snow.....
- LuvMyScamper
Thanks Rich! I think it's the outer seal we need.1972hiboy wrote:Cindy, Gave a call to my local jobber, Wasnt sure if you were looking for the inner oil seal that goes in the back side of the hub or the outter flange gasket that has 8 holes in it. So I got numbers for both.
Cindy
- 1972hiboy
If it is the outter seal you need it will be the same as a f250 with a dana 60
Rich
- LuvMyScamper
Oops I've just been corrected it's the inner seal we need, not the outer flange gasket, but you got that covered with numbers for both.
Thanks so much for the help!
Cindy
