68 f100 restoration.
- Fordkid68
Re: 68 f100 restoration.
Thanks Jimmy!!
Adam
My first truck,
^^Build Thread^^
(no other projects, YET!)
My first truck,
^^Build Thread^^
- Venomous duck
You are making some great progress. I may be able to offer some insight on those two holes in the firewall. They are for a dealer added a/c. The large hole is for the low pressure hose and the smaller is the high pressure hose. The need to be large so the fittings will fit through the firewall to connect to the evaporator hanging from the dash. It would have had grommets to protect the hoses and some dum dum to seal the hole. I am aware of this because my truck has the same thing and was untouched before I tore it down. You can probably see what I am talking about if you look back at my project update. Your doing nice work.
- Fordkid68
Thank you Duck!! I was wondering what the holes were for. now I know!
Adam
My first truck,
^^Build Thread^^
My first truck,
^^Build Thread^^
- Fordkid68
After a busy couple of weeks, I was finally able to spend some time in the garage.
Started stripping paint in the cab with flap discs, so I can paint the floors, and firewall, black. Also painted the rear shocks.
Adam
My first truck,
^^Build Thread^^
My first truck,
^^Build Thread^^
- Fordkid68
Here are the freshly painted shocks installed.
I also got some small holes in the rad support welded up. I had started working on it months ago, and started concentrating on the rest of the truck, and forgot about it! So now I am going to finish it. You do not have the required permissions to view the files attached to this post.
Adam
My first truck,
^^Build Thread^^
My first truck,
^^Build Thread^^
- hfdco4
Sometimes it's hard to keep up on everything. Looks like you are making progress though.
FE390PC
FE390PC
- 67mann
It's real easy to get side tracked.... take your time, document what's been done and needs to be done Your doing a bang up job thoughhfdco4 wrote:Sometimes it's hard to keep up on everything. Looks like you are making progress though.
- Fordkid68
Thanks guys, I really appreciate it!
Adam
My first truck,
^^Build Thread^^
My first truck,
^^Build Thread^^
- cumminskiller
Lookin good! You gonna reach your goal?
2017 Ford Fiesta ST = Daily
- Fordkid68
Thanks! I'm hoping to have it done, but I don't think the engine will be done in time.cumminskiller wrote:Lookin good! You gonna reach your goal?
Adam
My first truck,
^^Build Thread^^
My first truck,
^^Build Thread^^
- Fordkid68
I have still been making slow progress, but I guess any progress is good progress!
Got some small block engine-perches. Started cleaning them up and it made a huge difference! Next, I started working on the heater controls.
This is how it started. I got the whole thing torn apart. As you can see it was pretty dirty.
Adam
My first truck,
^^Build Thread^^
My first truck,
^^Build Thread^^
- Fordkid68
Here are all the main parts cleaned up.
The face is actually all chrome, that was just painted over black. I don't know if I should leave it chrome, or paint it how it was originally?You do not have the required permissions to view the files attached to this post.
Adam
My first truck,
^^Build Thread^^
My first truck,
^^Build Thread^^
Looking good Adam. I think it looks good black especially with new coat.
Troy
Troy
- JWW
Nice thread. Truck is coming along nicely.
JWW
1967 F100 Ranger, Auto, 240ci
2004 F150 Crew Cab
2004 F150 Crew Cab
- hdman90
It's been awhile since I've checked on your progress! You're cruising right along! Keep up the forward momentum!!!
