my green 68
- 48prerunner
Re: my green 68
Wow don't know how I missed this build, stumbled on it from a link over on ford truck forum on the sunpro gauge swap . Just read through the whole thing, Great truck really liked your idea for the wooden bed floor, did you go with a mustang tank? how is filling up in the bed?
- tybob81
Re: my green 68
I'm running a Tanks Inc tank because I wanted to run a in tank fuel pump. I fill the tank through a billet fuel door in the bed floor.
- 48prerunner
Re: my green 68
What did you end up doing with your ac vents? Any pics? I know you mentioned about two in a center console. I've read the ct article a couple times like how you mounted your switches.
- tybob81
Re: my green 68
Finished the hydro boost setup.
Re: my green 68
Very nice!
- tylerb43
Re: my green 68
That looks great, bud! Are you happy with it? How's does the system perform?
Where can I get those cool braided, bolt thru lines for the MC? I think I like those better than the standard looped hardline.
- tybob81
Re: my green 68
The brakes will throw you into the steering wheel if you don't watch it. I have not had much time to test it to much due to all this snow and junk weather this month. The braided lines and fittings came from Speedway. I used them because my stock lines didn't look good after bending them out to fit the new setup.
- marvin2
Re: my green 68
Tybob, I'm reading through some of the bronco hydroboost write ups, but I do not see anything mentioning modifying the BC Bronco mounting plate. What did you do to the plate / why was it needed?...or am I reading your post wrong?
Thanks!
Thanks!
- tybob81
Re: my green 68
I liked the way the BC bronco mounted , but the 67-77 bronco has a different firewall mounting holes so I cut it down and drilled holes. I like to research on the net, but then do it in a way that no one has done.
- marvin2
Re: my green 68
Ok, got it. If I didn't want to modify the bracket, would it be possible to just drill matching holes in the firewall?
- tybob81
Re: my green 68
If you want to.
- tybob81
Re: my green 68
Got bored with my gauges so I went with a set of Stewart Warner Wing series.
I also bought a vinyl firewall pad to cut up to fit my truck. Needs something since I changed my gas pedal due to the efi swap and all the wiring and such.
Re: my green 68
I think the plates are mainly to stiffen the firewall. if you dont want to spend the money on the bcbroncos setup you could check out thismarvin2 wrote:Tybob, I'm reading through some of the bronco hydroboost write ups, but I do not see anything mentioning modifying the BC Bronco mounting plate. What did you do to the plate / why was it needed?...or am I reading your post wrong?
Thanks!
http://www.locofomocoracing.com/page2.html
Liam is a great can and can help you out. and his bracket set up is cheap. I have one on my shop shelf now and can check it on my 70 truck if you want me to
Waylon
- marvin2
Re: my green 68
That would be great Waylon...I'd be curious to know. Thanks!waylon wrote:I think the plates are mainly to stiffen the firewall. if you dont want to spend the money on the bcbroncos setup you could check out thismarvin2 wrote:Tybob, I'm reading through some of the bronco hydroboost write ups, but I do not see anything mentioning modifying the BC Bronco mounting plate. What did you do to the plate / why was it needed?...or am I reading your post wrong?
Thanks!
Waylon
