Passenger side Air Inlet Duct
Does anyone know if the clips holding the Rubber Accordion Air Inlet Duct on the passenger side are available. They look like the bottom piece of Binder Clips. Has anyone found alternatives to these clips?
1971 F250, Camper Special, 360-2V, Manual Steering, 4spd
Re: Passenger side Air Inlet Duct
Here is photo of clip. I only have one, would like to get three more if possible.
- jzjames
You may find the clips are not that necessary. The rubber channel holds it on by itself
You're probably right, Thanks.
- Gaslight
I just finished mine a couple of months ago. I thought I was the first person to take it apart. But I did not have or know there were suppose to be those clips. The boot popped right on and no issues. I think you will be good.
Jake
Jake
1969 F100 Ranger
