Manual Steering Box Lube
FloridaFordGuy
Post by FloridaFordGuy »
Hi all,
I have a 70 250 with a manual steering box that looks like this:
Any idea what I should be putting in it for lubrication?
Thanks!
sparky72
Re: Manual Steering Box Lube
Post by sparky72 »
Service manual says to fill with SAE-90 EP engine oil, believe it or not.
Taylor
FloridaFordGuy
Well, that's convenient. Thanks for the info!
BTW, what manual is that? Think I should probably have one :D
Lee
Post by Lee »
FloridaFordGuy wrote: Wed Feb 01, 2023 6:24 pm Well, that's convenient. Thanks for the info!
Looks like the Ford Factory manual. My set is 5 volumes.
jzjames
Post by jzjames »
Recommend you use grease with the grease gun. Fill it up full.
The 90 wt. can leak past the seals.
FloridaFordGuy
Awesome. Thanks!
sparky72
Post by sparky72 »
Like Lee said, it's the '72 Ford shop manual. It's a reprint, not an original set. I forget where it's from but I believe you should still be able to get a hard copy from somewhere online, somewhere around $100 or so, perhaps a bit less. Or you can get digital copies for much less, but I like having the paper copies on the garage bookshelf :D
Taylor
