Horn not working
Blueford1
Horn not working
Post by Blueford1 »
Hello. I need some help with my horn. I have a new horn relay. When I press the horn button the relay makes a clicking sound, but no horn sound. I just need to figure out how the horn is connected to the relay. Currently, all the relay wires are connected to the voltage regulator and not to the horn.
1970 F100/302 5.0/4 speed/ Ford9inch 3.70
JWW
Re: Horn not working
Post by JWW »
Check this link to see for schematics. http://www.fordification.com/tech/schematics_h.htm
JWW
1967 F100 Ranger, Auto, 240ci
2004 F150 Crew Cab
My project: http://www.fordification.com/forum/view ... &sk=t&sd=a
Blueford1
Post by Blueford1 »
I've been looking at the schematics
No help.
JWW
Post by JWW »
JWW
2004 F150 Crew Cab
Russell J
Post by Russell J »
I'm just throwing stuff out there....but have you checked the ground at the rag joint?
Blueford1
Post by Blueford1 »
It should be grounded because the horn button clicks the relay.
basketcase0302
Post by basketcase0302 »
"Blueford1"I've been looking at the schematics
No help.
Check for voltage, (12 volts) on terminal wire#6 leaving the relay wiring harness here on this scematic:
