project updates
- jimmy828
project updates
have not posted in awhile but want to update on how far i have got with my project. The latest addition was installing power steering. Switching to power steering was a tough job but well worth it.
- Fordkid68
Re: project updates
Awesome trucks!! They look great! Power steering is definitely nicer to drive.
Adam
My first truck,
^^Build Thread^^
(no other projects, YET!)
My first truck,
^^Build Thread^^
- 67mann
Re: project updates
- jimmy828
Re: project updates
Finally got the side trim polished ,painted and installed. I think the blue pin stripe turned out pretty good. Also installed a Grant steering wheel.
- Fordkid68
Re: project updates
The chrome looks awesome with the pinstriping! It really ties it into the rest of the truck.
I like the looks of the Grant wheel, It makes bumps look so much sportier.
Adam
My first truck,
^^Build Thread^^
My first truck,
^^Build Thread^^
- cumminskiller
Re: project updates
I like the blue addition to trim as well. It's the little things.
1967 Ford F100 Ranger 2WD Shortbed = Playtoy
2002 Ford F250 Powerstroke 6 speed = Towpig
2017 Ford Fiesta ST = Daily
- MAK
- Location: Georgia, Blairsville - Florida, Flagler Beach
Re: project updates
Looks really great
Since converting mine to power steering I’ve only had the opportunity to move it around in the driveway a few times as it’s been in pieces as I do the bodywork and prep for paint.
- jimmy828
Re: project updates
Swapping to power steering was no easy job. Took over a year to round up parts but was in no hurry. Learned a lot with that swap.MAK wrote:Looks really great![]()
- MAK
Re: project updates
Yeah, finding that unicorn of a column was my biggest problem. Just didn’t do many 3 on the tree with power. I guess the guys who could spring for the power steering also went for the automatic. Then the inner shift tube needed some rust repair and welding...jimmy828 wrote:Swapping to power steering was no easy job. Took over a year to round up parts but was in no hurry. Learned a lot with that swap.MAK wrote:Looks really great![]()
Is that the factory “Bahama blue” on yours? Looks like my original color which I want to go back to. So far my only paint experience is with the epoxy primer... I’m leaning toward a single stage paint but have a lot of people who know more than me telling me I should do base coat and then clear coat. I just need the easiest method to allow me to deal with the inevitable runs and imperfections a rookie will get, not to mention a less than perfectly dust free environment.
- jimmy828
Re: project updates
The paint is called Speed Blue form TCP Global. I sprayed mine myself but i was advised by some experienced friends that do bodywork saying that if i have never sprayed car paint to use single stage so if i mess up it will be easier to repair. I must say they were right. My paint job is not perfect but do get good compliments from it. I have sprayed tons of [censored] cabinets being that is my career for the past 45 years but i found out that spraying cars is much more difficult.MAK wrote:Yeah, finding that unicorn of a column was my biggest problem. Just didn’t do many 3 on the tree with power. I guess the guys who could spring for the power steering also went for the automatic. Then the inner shift tube needed some rust repair and welding...jimmy828 wrote:Swapping to power steering was no easy job. Took over a year to round up parts but was in no hurry. Learned a lot with that swap.MAK wrote:Looks really great![]()
- MAK
Re: project updates
So what you sprayed was the single stage? It looks fantastic.jimmy828 wrote:The paint is called Speed Blue form TCP Global. I sprayed mine myself but i was advised by some experienced friends that do bodywork saying that if i have never sprayed car paint to use single stage so if i mess up it will be easier to repair. I must say they were right. My paint job is not perfect but do get good compliments from it. I have sprayed tons of [censored] cabinets being that is my career for the past 45 years but i found out that spraying cars is much more difficult.MAK wrote:Yeah, finding that unicorn of a column was my biggest problem. Just didn’t do many 3 on the tree with power. I guess the guys who could spring for the power steering also went for the automatic. Then the inner shift tube needed some rust repair and welding...jimmy828 wrote: Swapping to power steering was no easy job. Took over a year to round up parts but was in no hurry. Learned a lot with that swap.
