I’ve decided to try and fix this engine up rather than a full rebuild. Im doing some compression and leak down testing and labeled the cables, but on a whim decided to look up the correct firing order. This doesn’t look like what I’m finding online. What do you think?
It’s a 69 f250 with an FE engine, supposedly a 390.
https://imgur.com/a/STbj6vf
This firing order doesn’t look right?
Re: This firing order doesn’t look right?
Use this......it's correct and what I printed out to keep in the glovebox......
https://www.ford-trucks.com/forums/atta ... 1501300647
1997 Honda CBR 900RR
That is the correct firing order.
1967 F-100 4x4 custom cab.
