I messed up today stripped out fuel pump threads
- Godspeed128
I messed up today stripped out fuel pump threads Anyone ever do this ?
Re: I messed up today stripped out water pump threads
You mean fuel pump?
You can install a helicoil thread insert. Buy the kit, it's easy.
1967 F-100 4x4 custom cab.
- Godspeed128
Re: I messed up today stripped out fuel pump threads
You are correct I was a little upset
There are only two kinds of mechanics, the one's that have done this and the one's that are going to do it.
Heli coils work well but I would build a plate for this, glue it on with Gorilla Glue and wire in an electric fuel pump bolted to the frame with a independent switch. That way you don't have to work in close quarters and you have just built yourself an anti theft system.
There are two kinds of mechanics, ones that glue stuff together and ones that make proper repairs.
- Godspeed128
I'm thinking it's going to be Heli Coil I have never used them but i have seen videos on how the system works.
I studded mine for that reason. You can start it onto stud, compressing spring and not crossthread into aluminum. Also can hang gasket first.
- Godspeed128
Well it’s done now to try and install again it was had to line up last time it’s Like I was having to insert the fuel pump arm and push up to get it to line up correctly am I missing something ?
Stick you a mirror up there or feel with your finger where the fuel pump cam is. Installation will be much easier if you rotate the engine to where the pump operating cam is pointing straight up and not down on the pump arm.
Put some studs in there instead!
You know at the factory they had housewives installing the fuel pumps and it took them about 20 seconds.
- Godspeed128
Fortunately I’m not Mary anyone want to Lend there are wife out
Also what’s the best way to turn over motor by hand it’s newly rebuilt last year and I can’t get it to budge by hand I think It needs to turn just a bit for better fuel pump alignment
15/16" socket and breaker bar on the the crank bolt.
- Manny
sargentrs wrote:15/16" socket and breaker bar on the the crank bolt.
Yep that be the one....
The Junk that hangs around
1974 Bronco 302 3 speed
1984 bronco 302 c6 35's
1994 F350 7.3 5spd dually.
