72 F100 reg cab 302v8 no air. 3speed
I think its time to replace my blower motor.. Doesn't seam to blow very hard. Do I need to remove the heater box Or can I just unbolt the motor and pull it out with the fan attached? Will the fan fit though the opening? Or do I need to remove the box and take the fan off before I can remove the motor?
Thanks in advance. I found a few threads, but they are all with the heater box out of the truck. So I can't tell if they removed the fan first.
jb
Blower motor 72 F100
Re: Blower motor 72 F100
All you do is unbolt it and pull it out.
And check that full voltage is getting to the motor.
Check for junk in the box, mice like to build nests in there.jlb wrote: Doesn't seam to blow very hard.
Thank you. I will.cep62 wrote:All you do is unbolt it and pull it out.
If you do decide to pull it, go ahead and rebuild it and supercharge your fan. http://www.fordification.com/forum/view ... hp?t=73960
For the voltage? Just put a meter on it and look for 12 volts?jlb wrote:Thank you. I will.cep62 wrote:All you do is unbolt it and pull it out.
Yes , with the switch on high, and more than 12 if the engine is running.
Thank youcep62 wrote:Yes , with the switch on high, and more than 12 if the engine is running.
