new member from pa
A place for new members to introduce themselves
justintendo
new member from pa
Post by justintendo »
hi guys..i have been lurking for awhile now trying to gather info on these older fords and fe motors...i recently was gifted a 69 ranger 250 from my uncle..finally got it towed to my place this weekend..
truck is fairly original, and hasnt moved since late 80s. has the classic corner roof rot but is fairly solid, especially underneath..i gave it a good bath once home.
uncle has some nos parts for it....front grille and buckets, upper and lower body trim, various interior parts..
truck does have original 390 and c6 inside. i would really like to swap to a modern 5 speed manual as the resto goes, like a tko or the like. we recently parted his 70 250 that was a 390 with a four speed, so i saved alot of parts from that..
69 f250 ranger 390 auto 2wd
96 f150 eb 4.9 m5od 2wd
08 fusion sel 2.3 mtx
lennyp
Re: new member from pa
Post by lennyp »
:wel: from Massachusetts.
magic bus
Post by magic bus »
Nice truck and grille. Your fortunate to have all those parts!
71 F100 2WD Longbed Sport Custom 390 C6
67 Econoline E100 200 I6 3 on the Tree
70 Mustang Coupe 302 C4
97 Expedition 4x4 Eddie Bauer
67mann
Post by 67mann »
:wel: from NY nice truck
Manny
Post by Manny »
Clean good start for a truck. She will treat you right. Disk brake truck??? Like it lots welcome to the best forum ever. :fr:
The Junk that hangs around
1974 Bronco 302 3 speed
1984 bronco 302 c6 35's
1994 F350 7.3 5spd dually.
justintendo
yeah power disc, power steering..this site is definitely pretty awesome! im pretty solid on the 80-96 body style..as i have 7 years experience ford tech experience in addition to owning several fords..but these old girls are a little different. winters here but i hope i can post up some more pics with time.
crazyhorse
Post by crazyhorse »
Mr Justin :wel: to the best site period.
Hope you like it here. :pray:
Pull up a chair and stay awhile. :fr:
Good looking truck.
hdman90
Post by hdman90 »
Justin,
:wel: from Erie Pennsylvania! Where abouts in PA are you located??
Very nice start! Keep us posted!
justintendo
thanks for the welcome guys...im located in mercer pa.
im hoping the motor isnt seized...had a hard time getting the plugs out, then i sprayed a large amount of sea foam "deep creep" in each plug hole to let it sit for awhile. many things under the truck are pretty nice/solid, including the cab mounts..water dripping on the truck and getting on and in the engine bay was bad..
cstoyer
Post by cstoyer »
:wel: and looks to be a good project start point.
68 F250 4x4
Lone Ranger
Post by Lone Ranger »
Welcome from Michigan! Great looking truck can't wait to see more!
Kyle
Manny
Post by Manny »
justintendo wrote:thanks for the welcome guys...im located in mercer pa.
Just remembered i knew this trucks twin...
hdman90
Post by hdman90 »
Which also looks very much like this truck!
Manny
Post by Manny »
Them lights are hideous!!!! :eek:
hdman90
Post by hdman90 »
Manny wrote:Them lights are hideous!!!! :eek:
:lol: they are, but they're era correct! and you don't see them often anymore... I may just keep them!
