I was cleaning my exhaust manifolds today, in preparation for installing on my rebuild, and noticed that the studs going to the exhaust system need replacing. Any pointers on how to remove them? Also, does anyone know where I can find replacements? I'm not finding anything through google. I guess I'll have to check LMC.
Joseph
Replacing Studs on Exhaust Manifolds?
- colnago
Re: Replacing Studs on Exhaust Manifolds?
Napa has them. Double nut them or use a small pipe wrench.
1967 F-100 4x4 custom cab.
- eggman918
Steve
- Manny
Double nuts yes and then you need to soak crazy!! a propane torch or a true torch heating the area around the stud will help.. good luck they are a treat!
The Junk that hangs around
1974 Bronco 302 3 speed
1984 bronco 302 c6 35's
1994 F350 7.3 5spd dually.
- colnago
I got 'em! I soaked with the acetone/ATF mixture, then used a pipe wrench to grab in. Once they started moving, they came out fine. The threads on the manifolds were surprisingly clean. I was afraid that they would have rusted away over the last 50 years. Now I just have to find and install new studs.
Thanks, everyone!
Joseph
Thanks, everyone!
Joseph
