I have the tag info or at least some of it de-coded.
The question is... Are the bearings pressed onto the axle from the spline end toward the hub (requiring a shop do the service). OR Are the bearings (some what like the front wheel bearings ) driven / pulled out and new pressed / driven into the housing, with the axle then slid through the bearing during re-assembly ?
I'd like to know that I'm not opening Pandora's box... and I'd like to have the correct parts on hand, whether I do replacement or the shop does.
Truck is a stock 1970 Sport Custom
Ford F100 Differential Tag
WDM - S FORD
3.25 9 313A
Code Vehicle Ratio Ring Non- Axle
Application Gear Locking splines
WDM-S Ford Pickup '63-'72 F-100 3.25 9 in NL 28
