clutch install 1970 f100
I am going to install a new clutch in my 70 f100 4x4. I was looking for any tips on doing the install the right way as appose to the trial and error method. Thanks in advance.
- 71PA_Highboy
Re: clutch install 1970 f100
get a full kit... Clutch, pressure plate, throw-out bearing, pilot bearing.
If you can, get a 100% sintered bronze pilot bearing.
Pull ONE bell housing bolt. Go to the hardware store and buy 6 bolts that are the same thread pitch as the one you removed, but 6" long.
Drop both driveshafts, put a floor jack under the t-case, with the wheels of the jack fore and aft. Remove cross member
Pull the starter, replace all the bolts with the longer ones you just bought.
Remove the shifter linkage.
Slide the trans/tcase back, supporting the the bolts and the jack.
Remove pressure plate, clutch old pilot bearing, throwout bearing. Remove flywheel, have it resurfaced.
Reverse procedure for re-installation.
YMMV, I am doing this off memory...
Got Ford?
2 EarlyBroncos (68,69)
2 Classic Mustangs (69,70)
1 94 Ranger, 2.3, 5spd
1 Lincoln Mark VIII
1 Lincoln Mark VIII
- HIO Silver
After ya buy those long bolts, do ya gotta cut their heads off ? Or are the heads left on the bolts to prevent is sliding any further back?71PA_Highboy wrote:get a full kit... Clutch, pressure plate, throw-out bearing, pilot bearing.
01 Ferrari 360 Spider F1
01 F150 SuperCrew Lariat 4WD
01 PT Cruiser Limited (DD)
68 Mustang
65 Mustang
68 Mustang
65 Mustang
Don't forget to look at the flywheel surface and inspect it to determine if it needs to be surfaced or not.
2017 Ford Raptor
1975 Ford Bronco
2017 Ford Raptor
1975 Ford Bronco
The cross-member is huck riveted in...
Clutch replacement on F250, take the time to clean and ID all bolts for location, pulling tranny back using the rear crossmember will help keep the input shaft axially in a straight centerline with disc. May have to tap bell housing in a few spots to pop it loose from dowel pins, clean all surfaces and do the reverse when assembling, this takes minimum of 8 hrs. as the front tranny seal may need replacing.plan on min. of 2 days.
