The larger stuff I can UPS ship if you want-or if your anywhere around Gainesville Florida you can stop in and pick it up.
1) U-joints (one 1/2 ton / three 1 ton 1350 series)-$5.00 each
2) Obsolete dash pocket light (all the repo dash pockets have the opening for it) $5.00
3)Headlight switch (71 will fit many years) $5.00
4)79' blue Duraspark ignition box $5.00 SOLD
5) Moog and Elkin 1/2 ton and 1 ton front twin I-beam king pin rebuild kits $25.00 each
6) Used working 3G alternator $20.00 SOLD
7) Assorted obsolete OEM Ford engine and water pump pulleys (mostly small block-a few BBF) $5.00 each
9) NOS 250 CI 6 cyl thermostat housing $ 5.00
10) Used Ford OEM coil brackets $5.00 each
11) One used voltage regulator $5.00
12) Used 71' window cranks (loose black knobs) $5.00 pair
13) Used PCV / valve cover 90% plastic elbow connectors $1.00 each
14) Used brass intake manifold vacuum "trees" (multiple port vacuum hose connectors) $5.00
15) 71' used windshield washer plastic tank (mounts on DS inner fender) $5.00
16) Ford OEM coil brackets $5.00 ea. (I have two)
17) Dana 44 shim kit (for gear swap to get backlash set within specs) $5.00
18) Dual gas tank floor mounted valve/switch $5.00 SOLD
19) SBF engine fan belts $5.00 for all three
20) 16 ea 9/16" RHT lugs / 66 ea 1/2" RHT stainless and chrome acorn lugs / 9 ea 9/16" X 2.75 RHT dually wheel studs / 23 ea 1/2" RHT black steel acorn lugs / 8 ea 9/16" X 3" LHT dually wheel studs / 31 ea 5/8" dually lugs $5.00 per "bunch"
21) Ford PS pitman arm $25.00
22) New Champion (I have many other new sets-please ask) spark plugs $10.00
23) Ford SBF / C-4 aluminum transmission dowel $5.00
24) C-6 transmission filter with gaskets $5.00
25) Motorcraft 2150 carb rebuild kit, (complete except top bowel gasket-including a used one) $5.00
26) Wright brand 3/4" X 1" impact socket adapter $8.00
27) Sand blaster hood w tool, (tool needs suction hose easily acquired) $5.00SOLD
28) 3M respirator with new box of 3M prefilters / four new high capacity filters $15.00 SOLD
29) KD Tools engine ring compressor $8.00
30) KD tools engine hone (needs new stones easily acquired) $8.00
31) Ford TFI (80's Ford engines) module wrench $5.00
32) Ford & Chebby, (1/2" & 9/16") offset distributor wrench $5.00
33) Mr. Gasket engine degree wheel $5.00
34) Top post battery terminal puller $2.00
35) Nomex heat proof gloves, (think exhaust work) $10.00 SOLD
36) D44 front axle wheel bearing socket, (I have two) $5.00 each
37) Ford/York AC compressor NOS shaft seal kit (most common place your AC will start leaking freon $10.00 pics coming
Thanks for looking guys and God Bless America and all of you!
Edited 05/30/21'
