Well, it took me two years, but I finally got her started. This thing has been a garage ornament for two years. Back in 2004, I pulled the distributor to swap in an aluminum intake and holley 750 on my worn 460 in my 71 F100 short bed. Well, I got everything back together and started it up to take it to be inspected (inspection was out). I get about 5 miles down the road and it starts making a little noise. Seconds later, I get a BOOM and smoke out from under the hood. I tow it home and pull the motor. On dissassembly, i find the distributor drive shaft in the pan. No OIL= motor go boom! So I start building a new motor.
port some D3VE heads and have them rebuilt
bored the block and put in higher compression 30 over pistons
performer intake
holley 750 VS
long tube headers
mild cam
recurved duraspark dizzy
200 amp alt
Soon to come e-fan and AC
I have been slowly working on this and this past weekend I finally started it up to brake in the cam. It took a couple of trys as I was having carb problems, no it finally took it first breath Sunday afternoon. I'm still having carb issues, but its a start.
Austin
Finally got her started...new motor
- dablack00
- Heavenlyfire
re: Finally got her started...new motor
![Rocker :rock:](./images/smilies/icon_rocker.gif)
It's always a GOOD feeling when you get them to come back to life!!
Steve
69 F100 300I6
67 Mustang fb FE 431ci
72 Gran Torino Sport 351W
91 Bronco 351
69 F100 300I6
91 Bronco 351
Good news to share is the best kind. Congrats ![Smile :)](./images/smilies/icon_smile.gif)
- flyboy2610
![Clap :clap:](./images/smilies/icon_clap.gif)
Red Green
you'd better be right.
Red Green
- 1968flareside
Re: re: Finally got her started...new motor
steveheer wrote:![]()
![Yeah that :yt:](./images/smilies/icon_yeahthat.gif)
I didn't quite have your terminal problem when mine went down in 1996!!!! But I am slowly bringing mine back too.
Congrats!!!!
1968 F-100 Flareside
1999 F-150 XLT 4X4
http://www.fordification.com/galleries/ ... ?cat=10023
and
DON'T FORGET!!
1999 F-150 XLT 4X4
![FTE SUCKS :fte:](./images/smilies/icon_ftesux.gif)
![FORDification Rocks! :fr:](./images/smilies/icon_FORDification.gif)
- 460 crew
![Woohoo! :woohoo:](./images/smilies/icon_woohoo.gif)
- dablack00
I'm still having idle problems and I think it is a bad vacuum leak. I'm going to have to pull the intake and reset it. No big deal. I just need it back on the road, because I think the motor in my 68 cougar is about to go. I've been using the 68 cougar as my daily driver.
Austin
Austin
- marz68
