I believe i have a 1967 Medium Case Cruis-o-matic based on the bolt pattern of the transmission pan and the limited
stamping on the side of the case.
thought i'd change my filter the transmission oil filler tube is a headache.
Does that tube detach from any point? with the version i have the tube goes into the pan.
I tried to apply a minimal tork at the entry point into the pan and its frozen. I didnt want to tweak the whole assembly.
All bolts are out and the pans hanging there but i can pull down the pan.
