German guy is looking for power steering parts
nashkicker
Post by nashkicker »
Hi there,
I am working on a f-100 2WD, automatic transmission, from 1967 and looking for some parts. To upgrade from manual to power steering I need a gear box and a steering column for power steering.
As it is quite difficult to find fitting parts in Germany I hope you guys can help me out. I am grateful for any offer or hint where I should look otherwise. If you can't ship internationally I also have a contact in the US where you can ship to. Otherwise, I sure will take over the international shipping costs.
'51 Plymouth Cranbrook 4D
'60 Karman Ghia, sunroof
'67 Ford F-100
'03 Volkswagen T5
'03 Volkswagen Golf 4, 1.9 TDI, 150 PS, 4WD
hillcountryflt
Re: German guy is looking for power steering parts
Post by hillcountryflt »
Can you specify which steering gear you will be seeking - bendix or saginaw. Additionally, there were two lengths of steering columns from the 1967-72 era, I believe.
I do have a longer steering column for an automatic available. I was told it came off of a truck with power steering. I am doing the same conversion and will be using the shorter column with a saginaw steering gear.
It's not in the greatest of shape, but rebuildable.
Will you be needing power steering pump and bracket and cooler?
2016 Explorer;
2020 F150
2016 Harley Ultra Limited
2008 Ford Mustang Deluxe V6
nashkicker
Hi hillcountryflt,
Thank you for your answer.
Actually I only need a fitting set of a steering column and gear box. I have no preferences if it is a bendix or saginaw. As I have a 5.0 HO enginge from a Lincoln '91 I will use its pump & bracket and will build up a new cooler.
Can you send me a pic of your spare parts? What kind of column is it?
Cheers.
'67 Ford F-100
'03 Volkswagen T5
hillcountryflt
the column I have is from a 1969 F100 (I am told) with automatic and I believe a bendix style ps gear. It is longer than the one I am going to use. Will get a picture tonight or over the weekend.
2016 Explorer;
2020 F150
fast65
Post by fast65 »
I have a rebuilt Saginaw steering box from a 69 f100.
While I would ship, it's very heavy. Pm if interested.
