truck is a 72, i just stuck the one in from my parts truck, a 70, and the pumpkin casting is different, most recognizable difference is the one out of the 70 has a larger gusset from the axle to the pinion, and one of the leaf spring retaining u bolts goes through it, the 72s just has a short gusset, bolt does not go through.
i did not look at the ratios on the other truck, (a manual as well, but a 300 6) as i did not want to dig that out the snow drift too, i am already pressed for time to get the thing together, truck is sideways on an icy steep hill. it intersects the road up to my house there and i was plowing snow.
i rotated the pinion and counted, and they seemed close, and the one from the 70 fit in the same, if the ratios are close i'll run it, its the only one i can get at, and i already own it. i'll use it.
i was taking a brake for my frozen toes typing this, and a going back out.
anyone know what the axle differences are, ratios?
thanks guys
ill get a pic of the axle differences
