My name is Charlaine I'm a 30 mumble mumble disabled and retired veteran from the Evergreen State of Washington. I live in Spokane county. I served three tours of duty in Iraq. I love to fly fish, Model rocketry. Hike, camp, hunt, build things, garden and many other hobbies. I recently bought an 1969 Ford f250 Camper Special 360 5.9 v8 with the Ford C6 transmission. The name given by her very first owner is Pearl. So like the tradition of the sea she will keep her name. (I don't want the bad JUJU!!!) I bought her knowing she had some issues. Many from the complete lack of common sense of the po or his stupidity not sure which. So far with the help of the Ford Truck Enthusiasts Forums as well as This forum I have already learned about what some of the issues I'm having are and how to fix them. The list of issues and what I've fixed so are listed below. I'm also going to be asking a lot of questions. As I work to restore her.
- no oil( no really none zip nadda) the dang gum dran plug was loose and most leaked out. she took 5.5 quarts to fill to the right lvl
tranny fluid near empty causing hard shifting
cluster needed the ICR replaced.
Fuel Gauge selector switch needed to be cleaned and re-lubed
horns need to be replaced
mirrors are mismatched
headliner shot
carb is out of whack
suspect the need to replace timing chain
rear view mirror was missing the arm
exhaust manifolds need new gaskets and studs
Wipers had never been replaced
Plug wires where 45 years old and shot. Caused a fire as i was going to get new ones.
Both Pcv valved where shot.
Wiper res useless and in need for replacement.
and a bunch of other little things.
Since getting her I have
- Replaced the Icr
touched up the gauges and needles as well as readied to add new faces to the gauges.
Oil change and filter
replaced main and aux fule lines and added inline filters.
replaced pcv valves and elbow
replaced the cluster bezel
cleaned and relubed the tank gauge selector switch
replaced some of the little missing parts
found a second set of tires for summer
replaced wireset and cap
new wiper blades
going to be matching the mirrors
C6 tranny filter and gasket replaced
all fuses replaced
Newer arm rests
