Driveshaft lengt trans swap
Chuck2422
Post by Chuck2422 »
I need to know if 53 inches is what a driveshaft should be for a 1969 F100 SWB 390/C6. I measured 53 from tailshaft to middle of u-joint cap on rearend. I have read many posts and found a chart that now has me confused. I found three possible lengths between 53 and 55 roughly. I plan on getting my current 3 speed driveshaft to the shop this week and want to give them the length.
BobbyFord
Re: Driveshaft lengt trans swap
Post by BobbyFord »
Just call the driveshaft shop, they'll tell you exactly where to measure from and they build you a shaft based on your measurement.
Chuck2422
Post by Chuck2422 »
Thank you
