leaking cab
leaking cab
Is their a likley spot where water would be coming into the cab on the pass. side.It appears to be above the vent on the kick panel,I have had the whole front end of,and repaired the fire wall sill new inners etc.I know I have a fair amount of willow leaves in the cowl also(was not able to get them all out).Any probable spot?
1968 F-100 Custom Cab
300 6cyl 4spd
If it ain't broke,what the hell, fix it anyways !
300 6cyl 4spd
re: leaking cab
maybe right behind the vent in the cab thats where it likes to rot out
- willowbilly3
re: leaking cab
My 72 always leaked there too. It ran down the kick panel from under the dash somewhere.
re: leaking cab
As far as I know, the two most likely places to leak are the vent grille area, if it's all plugged up with debris, and don't overlook the windshield gasket.
Mine used to do this pretty bad, and I found 85% of it was coming in at the top of the windshield at the gasket. And the gasket looks ok, so the looks of it ain't a good test...
It then runs down the windshield frame on the sides, and then off down into the cab area, usually at the vents, but also usually around where your feet go. IE: brake pedal area, and ditto for the other side.
The way I cured it was to run a small bead of silicone along the top of the windshield gasket, so the water can't seep down into the seam. After I did this, my water leakage was cut by 85% or more. I still have a tiny bit sometimes if it really pours for hours, but I don't know what I can do about that. May be the body seals under the grille vent leaking a bit. MK
1968 F-250 / 300 six / T-18
Dana 60 - 4.10 Limited Slip
- heep70
re: leaking cab
Mine does the same thing. Everytime it rains and I take a left turn it just poors down the kick panel. Its my windshield gasket.
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
- Comet
re: leaking cab
Yeah, mine had that problem too. It' usually the windshield seal or junk plugging the drain in the cowl so water stands and eventually works its way into the cab.
re: leaking cab
Hmmmmm. My windsheild and gasket are new, the cowl was totally cleaned and I also have this, and don't recall having problem BEFORE I did body off rodstoration thingy. I'm kinda glad to hear it's not just mine ...
Trevor Rush
re: leaking cab
Are'nt you guys worried about your floor rotting out?gonna replace the pans in mine,but need to solve this problem first.
300 6cyl 4spd
300 6cyl 4spd
- Comet
re: leaking cab
Yeah, that is definetly the concern.
CACWBY, I had a new seal too. I wondered after they put it in if they put a thick seal on a thin windshield, but it was more than a year after that I noticed it.
re: leaking cab
I just ended up using some black silicone for now.Will take care of this in the spring.
300 6cyl 4spd
300 6cyl 4spd
re: leaking cab
Mine does that too in the 72 did all the body work new gasket and windshield and it leaks alittle add all the goop is a poor way to repair now i had the 68 f-100 done at a glass shop and they told me they all like to leak when replacing with new glass or seals so they put this black sealant on both grooves, on the glass side and the body side of gasket and guess what .... NO LEAKS, so now Im going to take the 72 in to them Im tired of the leaking ,put too much money in truck to continued to be annoyed by a stupid aftermarket windshield rubber that some glass guy states that you dont need to do that, hes come back twice ,put more poop on the seal area to have it still leak So guys a word of advice when replacing glass and or a seal have them use the good rubber sealant on the glass groove and the body groove insist on it!
Ford Is The Mountain That The Rock fell Off Of.
72 F-250 Camper Special 390 Stroker 419 CID 420 HP Natural Asp 200 HP NOS C-6 Dana 60 4.10
96 F-150 XLT 4X4 5.8 Heavy Duty 4EOD
re: leaking cab
there is a fool-proof way to fix this issue.
for the sake of your classic ford truck, move to a dry climate.
JESUS LOVES YOU! everyone else thinks your a jackass!
re: leaking cab
No thanks that sand and relentless sun eats rubber and paint not to mention sand into the cylinders at some point or another.
