edit. cab hauled to crusher still have hood and ps setup
Private parties only. No eBay/Craigslist listings.
roadhog304
Post by roadhog304 »
I have a 1967 ford F100 that I am parting out. I am keeping the grill, tailgate, and have already sold the seat out of it.
The hood is in excellent shape and has one very small dent on the driver side. no rust. I am asking $125 for it
The truck has a complete power steering setup on it. I will sell the box, pitman arm, pump, hoses, and auto steering column for $150.
The heater controls are in good shape and function. I am not sure what they would be worth?
There are lots of other good parts on the truck so let me know if you need something.
I am located in 67074 and prefer not to ship the big bulky items.
I can get pics this weekend.
67NCRANGER
Re: parting out a 67 ford f100
Post by 67NCRANGER »
What color is the interior? I could use a red driver's side fresh air vent if the tab isn't broken. Long or short bed? How's the trim? Rearview mirror?
Thanks, Rick
1967 F100 SWB Ranger Wimbledon White / Red Interior 352 3spd NO PS/PB
2012 Jeep Wrangler Rubicon Black/Black/Black 3.6L Auto
2013 Harley Davidson Softail Breakout Black 103 6spd
roadhog304
I am at work now so I cannot go look at the color. I think the vent part is black. The truck has no trim on it, long bed and I will check on the rear view mirror. Isn't 67 different than 68 and up?
kiroboy
Post by kiroboy »
Hi, Have a 1968 f100 Long box with C6 Auto, need the 2 piece drive shaft; The output yoke of the transmission is abolt on type with 4 bolts that connects to the front U-joint assembly to the front shaft!
thanks
Kelly
roadhog304
I have the drive shaft but it does not have a bolt on yoke, It is just a standard slip yoke.
Calvin Gunter
Post by Calvin Gunter »
How are the armrests ? Got any wheel opening mouldings ?
TIA,Calvin
1967 Ranger,Short bed,390,C-6,9 inch,4 BBL.,intake,cam,headers,3:55 Posi.,A/C,Power steering,Power Disc Brakes,Automatic trans.DJM dropped I-beams,flipped rear hangers,headlight harness upgrade.ExTang tonneau cover "Old Blue".
http://s508.photobucket.com/albums/s328/BigSxy96/
1967 Base model,352,2bbl.,3 on the tree,short bed,3:25 9 inch "Rusty".
1967 Mustang coupe-show car/garage queen.Small Block,alum. heads,Nitrous,4:11Locker,Areospace brakes "Mystang".
1996 F-250 Powerstroke-Big intake,exhaust,injectors.(Nice Smoke Show) "Big Sexy"
roadhog304
The arm rests are not that great as the do have some minor cracking but would be usable. I can get a pic or two if you would like me to. There are no wheel well moldings on the truck
To the the gentlemen that was looking for the rear view mirror it is a later aftermarket oreillys mirror.
jefflovesf250s
Post by jefflovesf250s »
Dear Roadhog: Looking for the bracket that holds/supports the 2 brake lines descending from the 2-chamber Master cylinder to the proportioning valve on the frame.
I believe it sits on the steering gear box and has part # C7 or 8TZ-2A275-?
I am re-doing a '66 F250, but converting the brake line system to a '67 to get the dual M/cylinder.
Any chance you have that bracket?
Thx. Jeff(lovesf250s)
roadhog304
Jeff, I think I DO possibly have the part you need. It is raining and dark outside so I only took a peek. If I can get home before dark tomorrow I will see if I can get it off and take a pic of it and send it to you.
jefflovesf250s
Thanks ur reply. Look forward to pic. Jeff
roadhog304
Jeff please pm me your email address. my pics are too big to attach on here.
jefflovesf250s
Roadhog: Sent you an e-mail with my e-mail address. Jeff
roadhog304
I will be hauling off the cab and everything left inside to the crusher Friday. I still have the hood p/s and some small stuff from the dash still. Later on I am making a trailer out of the frame and I will sell the front half of the frame with all suspension if anyone needs front suspension stuff. Make me an offer.
67NCRANGER
How does the driver's side inner cab corner look?
roadhog304
I think it rotted out but I will check.
