2wd conversion
2wd conversion
To save a lot of time can I put front and rear 4wd drive axles on my 2wd and install a divorced transfer case with driveshafts.would this work so I don't have to transfer my body engine and all to a 4wd frame? Please let me know. Thank you
- basketcase0302
Re: 2wd conversion
What model? It can be done...yet should be done only by the most experienced!
Otherwise a "hack job" that's not safe at highway speeds will surely be the end result.
This is not for the timid and requires a lot of work. You can follow Todd's build here that's going nicely. Dustin and one or two other guys here have done this I believe-maybe they'll pipe in here too with a little more info.
http://www.fordification.com/forum/view ... hilit=Todd
- averagef250
Re: 2wd conversion
If you have an F350 crewcab longbed then you have a great frame to combine with all the bits and pieces you can cut off a highboy frame to get the sought after crewcab longbed 4x4.
Other than that your nuts to not just locate, fix up and swap the 4x4 chassis under your 2wd body.
Re: 2wd conversion
Ok, Thanks for the advice guys. I will just put my frame onto a 4wd frame. I want to keep my truck automatic. So if I get a divorced transfer case and driveshafts this will work with my automatic trans? And of course I will use the axles that are on the 4wd frame. Thanks again
