Drop Pitman arm for 68 f100 4x4
Did a 4 inch lift on my truck. For now im keeping the manual steering box. I need a dropped pitman arm because right now its making everything run at a crazy angle. Where can i get one? Also, what about the track bar? Do i need to change something there or can it run at a high angle? Im kind of new to these trucks. Thanks for your responses, Will.
Re: Drop Pitman arm for 68 f100 4x4
I don't know if anyone makes the drop pitman arm
I also think the track bar should be lengthened beings you are moving the points where it connects away from each other. Hope this helps.
Doug
Doug
1967 f100 4x4
1970 f250 4x4
1970 f250 4x4
- basketcase0302
The graveyard should have both:
http://broncograveyard.com/?google=bron ... 4Aod5h241A
