A coworker of mine has an older Bronco, I forget the year, that he went rock crawling with last weekend. Now, the power steering works fine when turning left, but it's back to the old Armstrong method when turning right. He says he looked underneath and can't see anything bent or out of place. He wonders if a pinched hose could cause this problem, or maybe the steering gearbox itself is bad?
Any help is appreciated.
Thanks much!
A friends Bronco won't steer properly
- flyboy2610
Red Green
you'd better be right.
Red Green
- averagef250
Re: A friends Bronco won't steer properly
possibly a bad seal on the main piston in the box or dirt/damage to the torsion valve.
