axel removal
fonfixer
axel removal
Post by fonfixer »
I need to replace driver side brake backing plate, need to remove axel to do that. How does it come out? Anything holding it in? Searched through the forum and came across some scary stuff about pinion gears and backlash, don't want any of that. I watched my dad remove axel on 64 1 1/2 ton flatbed by removing tire and putting heavy chain on one of the lug bolts and popping the chain like a whip. Don't remember if he did anything else, been almost 30 years ago.
doug
1967 F100 swb 240 single barrel, manuel choke, three on the tree, style side
1967 F100 swb 240 single barrel, manuel choke, three on the tree, flare side
2011 F150 Crewcab Lariet w/Ecoboost (runs like a scalded dog!)
2019 Transit
forrestbump
Re: axel removal
Post by forrestbump »
Assuming you're working on a Ford 9" rear axle housing, you unbolt the 4 bolts found on the axle tube flange that retains the axle. If you have a slide hammer, use it, if not, flip a brake drum around, loosely bolt it to the axle and give it a few good pulls (slide hammer like) and you should be able to pull your axles out.
Larry
ForingaMex
Re: axel removal
Post by ForingaMex »
Fist we need to know what kind of truck it is on. F100 or F250/350?
-Jake
"Better to remain silent and be thought a fool than to speak out and remove all doubt." -Abraham Lincoln
-02 Dodge Ram Quad Cab
-72 Ford F100 LWB 390/C6 (Retired for now till I can rebuild/transform it)
-2000 Ford Windstar (Family Vehicle)
-92 VW Beetle (Mexican)
fonfixer
Re: axel removal
Post by fonfixer »
Thanks Forest, worked like a charm. First time pulling an axel. Pulled the one at the junkyard first, rather learn there then on my truck. Found there is nothing to it. All that trouble because of trying to do brakes.
2019 Transit
