Will the rear brake hose from a '75 highboy work in a '68 Bronco Graveyard sells the '75 but not the '68.
Steve.
High boy rear brake hose?
- eggman918
Steve
Re: High boy rear brake hose?
Hey eggman,
According to the Raybestos website, the hose for the Bronco is 15.5" long versus the highboy which is 24 5/16" long. The threads should be the same at both ends. The only thing that might be a problem is the bolt hole in the 't' end of the hose. I don't know if it will be the same size. You should be able to get both hoses at an auto parts store to compare.
Mark
Mark
- eggman918
Yes I am needing to replace the hose on my '68 and the length is my biggest concern.I ordered one from Bronco Graveyard,I am tired of the blank stare I get at the auto parts store
when I tell them I need parts for a '68 Hard to find a skilled counter person here
thank's for the input Steve.
Steve
- BobbyFord
Check out Dorman Products...> http://www.dormanproducts.com/c-172-brake-hose.aspx
Just input your vehicle info at the top left for the part number, any auto parts store should carry or be able to get it.
- eggman918
Thanx Bobby The magic code to bypass the terminal operators apathy
Steve.
Steve.
Steve
