I am having problems with my speedometer on my '95 mustang. I have removed it from the trans- and inspected it, and it appears that it is in good condition. Lubricated it, etc. Would it be associated with a sensor that needs fixing or would the speedometer cable need to be replaced? Thanks for looking.
cloudwalker
95 Speedometer
- cloudwalker
95 Speedometer
“It’s not the critic that counts, not the man who points out how the strong man stumbles, or where the doer of deeds could have done better. The credit belongs to the man who is actually in the arena.” Teddy Roosevelt
Re: 95 Speedometer
spin the inner cable and see if the dahs speedometer turns. if it does then the broken part is in the trans. unless the inner cable is a electronicly controled deal. are there any sensors in or on the speedo cable? if so they might be able to be tested at the parts store.
- cloudwalker
Re: 95 Speedometer
Thanks for the quick reply fordman. As I was inspecting the cable, I had another helper watch the speedometer as I tinkered with it. When I re-lubed it and reassembled it, it started working the way it was supposed to.
cloudwalker
cloudwalker
