Brute Power clutch kit
wareaglef100
Post by wareaglef100 »
What about this one. Seems like I read something at one point that Brute Power bought the clutch stuff from Borg Warner???
http://www.amazon.com/gp/product/B000BZ ... PDKIKX0DER
1970 F-100 2wb lwb
Olive Branch, MS
71highboy
Re: Brute Power clutch kit
Post by 71highboy »
i dont know about borg warner clutch parts but their points -coil-most other parts are now made in mexico :2cents:
wareaglef100
no bueno
1970 F-100 2wb lwb
Olive Branch, MS
knightfire83
Post by knightfire83 »
That particular item above is made by perfection clutch ~aka Brute Power ~aka Zoom Clutch. Borg Warner also has a Brute Power line of products, but is not affiliated with the other company.
From their site:
"Perfection Chinese produced product 100% engineered to OEM tolerance and performance specifications"
http://www.perfectionclutch.com/clutch.html
Personally I have been running a RhinoPac clutch set, it is made by AMS automotive. I've had absolutely no problems with it for the past 3 years. Haven't even needed to adjust it yet. (360, 4x4, daily driver)
http://www.amsautomotive.com/kits_rhinopac.php
bought it from rockauto.com
1974 Ford F-100 4x4- 360 / manual.
1970 Ford F250 4x4 ~ Sold.
wareaglef100
knightfire83 wrote:That particular item above is made by perfection clutch ~aka Brute Power ~aka Zoom Clutch. Borg Warner also has a Brute Power line of products, but is not affiliated with the other company.
From their site:
Which one did you get from rockauto.com (i.e., part#)?
1970 F-100 2wb lwb
Olive Branch, MS
knightfire83
RHINOPAC Part # 07027
Northland; Disc Spec: 11" OD X 1-1/16" ID X 10T, Flywheel Spec: FLAT; Lever Style; w/ 11" Clutch
Custom; Disc Spec: 11" OD X 1-1/16" ID X 10T, Flywheel Spec: FLAT; Lever Style; w/ 11" Clutch
Ranger XLT; Disc Spec: 11" OD X 1-1/16" ID X 10T, Flywheel Spec: FLAT; Lever Style; w/ 11" Clutch
Ranger; Disc Spec: 11" OD X 1-1/16" ID X 10T, Flywheel Spec: FLAT; Lever Style;
http://www.rockauto.com/catalog/moreinfo.php?pk=200240
At the time it was $117.79 but now is $124.89.
427
Post by 427 »
I,ve been running a super brute force behind my 427. Its been abused since day one. Not had any slipping issues as of yet. Been in there about 8 years. However I don,t drive it daily.
68 f100 427 r code 4spd toploader
69 f350 390 4spd hauler bed
72 Ford Bronco 302 3spd
95 Ford Lightning
38 John Deere G
Assorted old Honda ATC,s
