mud tire sizes
- BRUTUS_T_HOG
mud tire sizes
what is a good size for mud tires that look decent on a bump? im not looking for a HUGE tire..
from pictures i have seen 33-35" would be sufficient? but im not sure. i like the look/function of tall skinny tires.
i guess what im fishing for is pictures and tire sizes.
ASE Certified Technician
- averagef250
Re: mud tire sizes
I use 35"s on mine. I have run 255/85R16's and loved the size for use, but it just wasn't big enough for me. If you want taller than 33.5" (255/85R16) and skinny I'd suggest going to a 19.5 wheel where many commercial tire sizes can be had around 35" tall.
- BRUTUS_T_HOG
Re: mud tire sizes
255/85R16 sounds perfect. do you have any pictures?
i don't have a lift or plan on getting one so the pictures i've found don't do me much good for reference
- averagef250
Re: mud tire sizes
What kind of truck do you have? 255/85"s will not fit on a 2wd or F-100 4x4 without a lift.
- In FORD we trust
Re: mud tire sizes
I am running 33x12.5x16.5 I like the look. I have no clearance problems at all. Here's a pic. Tim
68 F250 4x4 Ranger LB
08 F350 4x4 Diesel Quad Cab LB
64 Fairlane Post Pro Tour Project
Re: mud tire sizes
I like 285/75-16s.
Basicaly the same as the 255s suggested by Average but wider. Looks good with 16x8 wheels.
Doug
Doug
1967 f100 4x4
1970 f250 4x4
1970 f250 4x4
- averagef250
Re: mud tire sizes
Good point Doug. I should have added that a 255/85 should be on a 6-7" wide wheel. They look goofy on an 8" wheel
Re: mud tire sizes
255's look good on stock wheels with hubcaps....Well at least I think they do
Doug
Doug
1967 f100 4x4
1970 f250 4x4
1970 f250 4x4
- BRUTUS_T_HOG
Re: mud tire sizes
that looks perfect! i like that size. i don't even remember what size it has on it right now, but i don't think the wheels are stock.. they are 16" rimsIn FORD we trust wrote:I am running 33x12.5x16.5 I like the look. I have no clearance problems at all. Here's a pic. Tim
and mines a F250 4x4 btw. i can't wait to start driving it again!
i've been driving my 89 ranger...
Re: mud tire sizes
I have 315/75/16s on my f-250 and I like the height and how they fill up the wheel wells.. They look a a little funny because they are fat but they work.
I have to decide if I am going to stick with this size or go up to some 17 or 18s. I thought about 19.5s for a while but probably wont unless I start logging a hell of a lot of miles on my truck.
71 3/4 ton 4x4 highboy
68 Mercury Monteray
68 Mercury Monteray
- averagef250
Re: mud tire sizes
It's very unusual to find a 15" wheel on a 3/4 ton truck.shivam wrote:245-75-15 maybe 265-75-15 have fun in the mud...
Re: mud tire sizes
40 inch ground hawgs, with 3 inch body lift and custom sawsall work.
