C 6 Question
C 6 Question
Can you tell me what means those numbers (like: 64, 65...) in the top of any C6 transmission?
Re: C 6 Question
I'm still trying to figure out what means those number in the bell housing top. Anyway, My F100 71, eng 302 and with C6 transmission recently installed is not engaging any forward gear only reverse. But, if I give it high RPM it engages but makes a kind of bump inside the transmission. Can you help me? I appreciate that. Thanks.
Re: C 6 Question
those numbers dont mean anything to us. all your info would be on the trans tag on the passenger side of the trans. i am betting the band adjust wedges fell out of the bands. drop the pan and you will probably see some wedge looking pieces in the pan. those are part of the adjuster for the forward clutch band.
