divorsed T/C brace/strut? need pics
- eggman918
I know some NP/205s came with a 'strut' from the bottom of T/C to trans crossmember I think? Can anyone send me a pic.I am upgrading my dana 24 and I need to know where to start
Steve
- basketcase0302
Re: divorsed T/C brace/strut? need pics
eggman918,
I've got an "oddball" crossmember here that came off of my 205 case. It was not a divorced type, but it was a "Pathfinder" conversion done on my 79' E-350 van. It is an "oddball" mount for sure! I think it might be kinda' what you're looking for.
I'll try to snap a picture of it tomorrow, (gotta' love it being dark at 6:30 P.M.).
Basketcase
Basketcase
Many, but not all, 73-77 F-250 4x4's with the NP205 case came with this factory strut rod that consisted of a plate that bolted to the NP205's lowest rear cover, a tube that bolts to one of several adjustment holes in the lower bracket and an angled bracket with rubber shock bushings that's riveted to a frame crossmember.
This strut rod is very easy to adapt to any '67-'72 F-250 4x4 after swapping in an NP205 case. The strut rod will have to be shortened several inches due to the difference in wheelbase from '67-'72 trucks vs. the '73-later trucks, but works very well and appears factory.
- eggman918
many thanks, that will fill in many blanks
Steve
The t-case struts only came with automatic tranny highboys not on the manual tranny highboys (dentsides).
Jim
'75 Ford Highboy 390 4spd
- eggman918
I have been told that they help with heavy trailers while in 4WD... True?
Steve
- Manny
eggman918 wrote:I have been told that they help with heavy trailers while in 4WD... True?
It helps with torque load yes. It also was a big advantage on married mount setups due to the shear weight of the 205's. Here is a pic of a t-18, and a np205 i just picked up out of a 78' 250 extended cab 4by4. This is a married mount but also shows another style that can be used to help stir some ideas.
This is the best pic of it notice the two l brackets and the bushing just outside the output of the case. Simple but effective
http://www.supermotors.net/getfile/7718 ... c02385.jpg
Just another angle if it helps
http://www.supermotors.net/getfile/7718 ... c02386.jpg
The Junk that hangs around
1974 Bronco 302 3 speed
1984 bronco 302 c6 35's
1994 F350 7.3 5spd dually.
- eggman918
Steve
