Pressure Washing
Pressure Washing
Whats the consensus? is it ok to pressure wash a motor while it is running with cold water? or do you risk cracking the block?
Re: Pressure Washing
If you just started it, i can't see where it'd be much of an issue. If you drive it a couple of hundred miles & decide to give it a bath, it might not end well.
- Sam I Am
It should be fine as long as it doesn't have aluminum heads or block.
It shouldn't hurt old school engines at all but you might want to cover the distributor with a Wal Mart plastic sack.
And instead of cold water, find a good car wash that heats up the water and it will clean even better.
i go to the car wash and do it. i also put a rag inside of the dist cap and put it back on while i wash it. take a can of wd40 with you incase the rag got wet. you can remove the rag and spray the inside of the dist cap to disipate the water.
- 72bumbee
I could almost swear I killed my coil by pressure washing my engine while it was running. I had a baggie over the dist. and was mainly hitting the front and bottom of the motor.
Mark Twain
Mark Twain
- sideoilerfe
If you wash it with hot water than it shouldn't be an issue. Hot water works better anyway.
1970 F250 4x4 390/4spd
1968 F250 4X2 360/C6/No Rust!
