What would be redline??
FordTruck
Post by FordTruck »
I was courious what would red line be on the old 302 in my 70? I know it spins 3g doing 40 it seems like alot to me but I know its nothing for the motor. So I was just courious what would you guys say red line would be.
60 Mercury Comet
65 Ford Econoline
77 Ford F250 "lowboy" 4x4
09 Harley Xl1200c
MadMaxetc
Re: What would be redline??
Post by MadMaxetc »
5k for a stock 302. If you upgrade the valve train, better headgaskets, etc... you can get 6500. Some guys run 7k shift points...but they are nuts.
Dan
FORD Girl
Photobucket Pictures
sideoilerfe
Post by sideoilerfe »
3grand doing 40 mph 1:1 final drive ratio? You've got problems. that is way to high. Too tall gears with too small tires, tranny/clutch slippage or your tach is wrong.
1970 F250 4x4 390/4spd
1968 F250 4X2 360/C6/No Rust!
FordTruck
Post by FordTruck »
sideoilerfe wrote:3grand doing 40 mph 1:1 final drive ratio? You've got problems. that is way to high. Too tall gears with too small tires, tranny/clutch slippage or your tach is wrong.
Its got either 3:50 or 55 I can't rember witch. My tires are 235/75/15. Its got a C6 it seems to be shifting through all 3 gears but 3g does seem really high to me. I'll have to check into my tach I might just warrinty it out and get a new one :lol:
60 Mercury Comet
65 Ford Econoline
09 Harley Xl1200c
