Hi , my Rustang has developed a bit of a quirk of hesitation off a standstill. But the odd thing is I can punch it all I want once I'm moving and it doesn't hesitate it just takes off as usual. Also again this is trying to get moving when it hesitates , it does fine at anything above 20 mph.
Thanks
Chaseman
Hesitation off standstill , 1966 289
- Chaseman
Re: Hesitation off standstill , 1966 289
that is the accelorator pumpin the carb going bad. they work fine once they get going. but will hesitate when you start from a stop.
- Chaseman
oh man my dad just rebuilt it as a B-day present , is there a way I can check? Also let me better explain my hesitation , It is more severe when I try to gently pull from a stop and happens less when I jump from a start. Could it be dwell or timing , my dizzy came loose and thought that was the reason for my hesitation ( it was way retarded) but when I turn the timing high enough to make the hesitation go away , I get bad detonation during when I give it gas in third at anything below 35-40 course that could be of my tranny's dislike of downshifting automatically.
well then maybe it isnt that accelorator pump then. if it done it at a high stomp from a stand still it woudl still hesitate. somaybe it is the timing or a spark related issue.
- Chaseman
Oh! Yes that makes sense , I've checked my Brake booster hose but I completely forgot about the vacuum modulator. Thank You!
You can also take some carb cleaner or Berryman's b12 and squirt it around the carb and intake. If there is a vacumum leak that you can't see it will suck in the chemical and the idle will temporarily rise
Vacuum advance gone bad?
2015 lifted Toyota tundra 4.6 4wd
2002 Toyota Sequoia 2wd 4.7 auto
1989 Ford F150
1979 Chevrolet C10 350/TH400 14 bolt "Big 10" (DD)
1972 F100 parts truck long bed
1971 F100 2WD LWB 302 aod 3.70 9inch PS pb
1966 International Scout 800
1954 GMC rat rod project Scout frame, inline 6, T90 4X4
1953 Chevrolet Tin Woody
1946 Hudson BigBoy Pickup-ratrod project
1989 Ford F150
- TNIceWolf
Try checking for a broken or loose engine mount. That allows the fuel in the bowl to slosh around.....causing a stumble under load......... its not under as much load at speed.
Presently in the stable
1969 Ford F-350 DRW
1969 Ford F-350 DRW
