'72 D44 disc swap
1970Custom
'72 D44 disc swap
Post by 1970Custom »
So I picked up the front axle from a '72 F-100 and it looks identical to every other 44 I've seen other than it's drum.
Can I swap the disk system off of the TTB44 onto this axle? I know the usual swap is '73-'79 but I will soon (if the swap is possible) have a TTB44 laying around...
Hi, I'm Eric and I have a bumpside addiction.
averagef250
Re: '72 D44 disc swap
Post by averagef250 »
If your 72 axle is a balljoint version you can use the TTB44 knuckles out on your early housing. The outer axles are the same.
If you have a trunnion housing you can't change knuckles.
1970Custom
averagef250 wrote:If your 72 axle is a balljoint version you can use the TTB44 knuckles out on your early housing. The outer axles are the same.
I know ball joint style but what does the trunnion style look like???
71PA_Highboy
Post by 71PA_Highboy »
4x4 kingpins. There are 4 smaller bolts holding the kingpin cap on... Balljoints will have 1 BIG nut.
HTH,
Eric
Got Ford?
2 EarlyBroncos (68,69)
2 Classic Mustangs (69,70)
1 94 Ranger, 2.3, 5spd
1 Lincoln Mark VIII
