The 69 f100 I bought is in bad shape...cab..floors..bed..the only thing thats good is the I-6..and its not the one that came in it..so what would you do?
Rebuild the 6..find a 69 I-6..or put a 360 W/air and p/s??
Keep the 6(its not original)or 360?
- oleman69pu
69 F-100's Rule!
Re: Keep the 6(its not original)or 360?
maybe find a truck thats in better shape to use the motor in?
- convincor
that was my first thought.70shortwide wrote:maybe find a truck thats in better shape to use the motor in?
"Still Plays With Trucks"
- oleman69pu
I have found a cab so thats not a problem... ...so what would you do on the engine? I'm thinkin..360
69 F-100's Rule!
- FreakysFords
Were it me and the 6 was in good shape and was installed correctly, I'd leave it and have a fine torque happy driver / worker. That said, I'm a HUGE FE fan and there's always room for a good FE.
In other words there's no wrong answer to this question, so do the "work sheet" thing and decide what works for ya
example
1) 240 or 300 (either is a FINE engine) and what's it's condition
2) What's the KNOWN condition of the 360? (IE how much $ needs to be spent on oil leaks, carb, etc)
3) What all will need to be sourced to make the swap (assuming the 6 is in good order, weigh against).
4) what's more important to you as far as milage, feel, etc?
example
- ToughOldFord
I'm a big fan of FEs, but with today's fuel prices I'd keep the six.
And a major plus is the ease of working on an inline six.
Even better part of the 6, besides easier to work on, is not having to work on it very much.
67 F100, 300(Offy intake, Edelbrock 500, 274*/.518" lift cam, heddder, duraspark & Summit CD ign), 4spd, power steering swap, front disc and hydroboost.
08 VW R32
increase diesel fuel rate site:
http://www.freewebs.com/nevrenufhp/index.htm
08 VW R32
