front 68 F250 replacement axle?
zakt
Post by zakt »
I have the stock 68 F250 axle, I assume Dana 44 (drum brakes). Now is the 76-79 have a dana 60 front disk brake axle that will bolt in?? Thought about buying a new axle but thought the ball joint new ones might not be as good??
Todd
1972 Ford F350 crewcab
Wes
Re: front 68 F250 replacement axle?
Post by Wes »
The 761/2 - 79 F250 have dana 44's I believe the snowfighter option had a D60 and I think f350 had d60's the 79 f350 should have a high pinon d60. so far that what my research has uncovered. I'm sure someone will have more on the subject
Wes
67 F250 High boy
69 Bronco
averagef250
Post by averagef250 »
The balljoint axles are much better.
BigBlueF250
Post by BigBlueF250 »
I put a 76 unit in my 69 F250. Alot of people prefer that later ones because of the high pinion though. Mine was a simple bolt in swap.
Steve
