does anyone know what size bolts were used on a 71' swb f100 bed to frame?
thanks.
bob.
Bed to Frame bolts
- frisky
Bed to Frame bolts
71 f100sb 390/edelbrock everything, 66 F100sb 240ci, 36 flathead pickup, 30 A roadster, Cat D2, Basset Hound Tucker.
- 4x4x4crewcab
re: Bed to Frame bolts
These are the sizes listed for my truck (1970 crewcab shortbox)
qty (4) 1/2" 13 x 3 1/2 carriage
qty (2) 1/2" 13 x 2 3/4 carriage
qty (2) 1/2" 13 x 1 1/4 reg. bolt
front of box position 1 (carriage) use the 3 1/2 length x2
next back postion 2 (carriage) use the 2 3/4 length x2
next back position 3 (carriage) use the 3 1/2 length x2
last position rear most (bolts from the underside) use the 1 1/4 length
hope this helps. I would imagine them to be the same
Mark
1969 Volkswagen Karmann Ghia
1999 Ford Windstar
1983 Chevrolet Silverado p/u
1990 Lincoln Town Car
1998 Lincoln Town Car
1999 Ford Windstar
- Joshpow
Those figures are correct with what I have on my 71 SWB.
Josh
72 F-100 Ranger XLT SWB
71 F-100 Custom SWB
67 F-350 Dually Dump
02 F-250 Stroke
71 F-100 Custom SWB
02 F-250 Stroke
- frisky
Thanks!
I looked at LMC Truck catalog today and they show the hardware ala cart but dont give dimensions, and its not clear if its hardened or just regular hardware store grade stuff. I read somewhere else that regular hardware might snap in an accident or exceptionally heavy load and could lead to bigger trouble.
I think Tractor Supply has hardened carriage bolts, and will take a look this weekend.
Bob.
Bob.
- DuckRyder
You might check with Totally Stainless and AMK as well.
- frisky
I got the LMC bolts I ordered, grade 3 markings on the heads. Better than the stuff at the Orange hardware place, but I was hoping for something stronger. Will try my buddies at Tractor (Ford) Supply tomorrow.
