Body to frame insulators / washers for 67-72
Any idea where to get them? :?
I can find kits for Broncos and 73 up 4x4, but not a 72 2wd. :x
I need a few of the metal washers as well. :$$:
Anyone?....? :hmm:
willowbilly3
re: Body to frame insulators / washers for 67-72
Post by willowbilly3 »
I'm sure I saw them in a catalog somewhere. I will look tomorrow and see if I did.
FORDification
Site & Forum Admin
Site & Forum Admin
Post by FORDification »
You're basically talking about the cab mount kit? I got mine from LMC. I can't find my Summer 2004 catalog, but if you've got the Spring catalog (FB20) look on page 31, upper right-hand corner. They're not the same as the factory pieces though, so you can't mix & match. Actually, I've decided to re-use a good pair of factory insulators I have for the cab mounts, but will use LMC's radiator support mount kit. Each are $50.
Here's a comparison shot of the two different styles. The new LMC cab mount is on top, and a used factory mount setup is on the bottom:
willowbilly3
When I rebuilt my 72 12 years ago no one was repoping the mounts and I had to reuse my old squished ones which required some extra washers in places to get everything line up after installing the new floorboards and cab mounts.
Yeah I guess I do mean cab and radiator support mounts.
The ones I need worst are radiator support mounts.
They aren't that bad, but the washers, particularly on the right side are pretty cruddy.
I por 15'ed them in preparation for re-use.... :wink:
F10Y
Post by F10Y »
I just found out that I need the bottom rubber, washer and nut on cab to chassis mount. Was wiring the transmission cooler line up off of the exhaust and hit my head on the bolt and pushed it up. That's when I noticed that it was missing.
Michael
1972
F-100 2WD
V8-360
