hope this is a help
http://www.pirate4x4.com/tech/billavista/8274/
warn winch wiring schematic or control box
Moderator: Doug Comer
- binder56jd
re: warn winch wiring schematic or control box
now serving #235
now serving #235
- 72hiboy4x4
that is exactly what I was looking for.
Funny, I went thru what I could find of billavista's stuff but never did run across that!
Oh well thats why you guys are the best source for info like this!
Thanks, Mike
Thanks, Mike
- binder56jd
i got lucky- that guy has some very good and detailed stuff- good luck with the winch
now serving #235
now serving #235
- averagef250
Can't beat the 8274's. Pull twice as fast as any other winch and don't stop until the cable snaps or your bumper tears off. That's how a winch should be, not the new planetary, plastic geared, ultralight junk that the new models are.
- averagef250
Sorry about trashing your M8000. They're not that bad. If someones winch shopping they can usually pick up a good 30 year old 8274 for $300 that will outpull any new planetary winch at 1/4 the cost of buying one new.
- 72hiboy4x4
somehow I missed this post.
and don't worry about trashing this thing, I wouldn't know the difference anyways!
I picked this one up for $80, and the guy said he wasn't sure it worked or not, cause he got it in a trade.
so I'm still trying to get a control box built for it, so I can see if I need anything for it. Then I will get it mounted on the car trailer, and be a happy camper.
