Basketcase parts final round
Re: Basketcase parts final round
By chance would you have the wire for dual horns? Yellow wire with 2 black connectors that comes out of the harness on the passenger side by close to the battery.
1997 Honda CBR 900RR
- basketcase0302
Sorry I don't have that wire. I remember making one for my 79's dent and running it through the core support for protection from one side to the other.
I believe you might be able to get the terminal ends and make that wire easy enough try here for the insulated connectors:
http://www.wiringproducts.com/ford-connectors-sockets
Thanks Jeff - if I can get the connections I can do the rest.....I just want it to look stock......damned OCD.......basketcase0302 wrote:Sorry I don't have that wire. I remember making one for my 79's dent and running it through the core support for protection from one side to the other.
- basketcase0302
BUMP!
- basketcase0302
- basketcase0302
Revised / updated the list guys.
I still have these.
I still have these.
Basket case I'm in Chattanooga. Where are you located?
What is the shape of the 15) 71' used windshield washer plastic tank? Does it come with the pump?
- basketcase0302
I'm a stones throw from the airport here in Nooga' just off of Hwy 153."XABN82"]Basket case I'm in Chattanooga. Where are you located?
Let me dig it out this afternoon to verify this.DisneysPatB » Wed Mar 07, 2018 11:43 am
Shoot me a pm with your email if you'd like a picture of it, (as I won't play "hostage" to photobucket or any other date "storage" host for money).
- basketcase0302
basketcase0302 wrote:I pray all here have been bumping along fine. Had to sell the DRW last year and don't know when my next bump will come along at this point so it's time to get rid of some inventory of my 30+ year collection of Ford truck parts as I ponder heading back farther South. Below is a partial list-but by no means a complete list of what I have for sale, (mostly small parts / no body parts / but please ask if you don't see it) and most parts are used unless specified. I've also put a link to the photobucket list of pics for most of the parts and tools listed below. Most of this stuff can be flat rate shipped in the small box via USPS for $5.90, (which includes a tracking number but no insurance) insurance usually runs an additional $1.30. Please send me the list of what you'd like and the city / state / zip code / residential or commercial address for an accurate shipping quote.
The larger stuff I can UPS ship if you want-or if your anywhere around Chattanooga you can stop in and pick it up.
http://s240.photobucket.com/user/basket ... t=3&page=1
1) U-joints (one 1/2 ton / three 1 ton 1350 series)-$5.00 each
2) Obsolete dash pocket light (all the repo dash pockets have the opening for it) $5.00
3)Headlight switch (71 will fit many years) $5.00
4)79' blue Duraspark ignition box $5.00 SOLD
5) Moog and Elkin 1/2 ton and 1 ton front twin I-beam king pin rebuild kits $25.00 each
6) Used working 3G alternator $20.00
7) Assorted obsolete OEM Ford engine and water pump pulleys (mostly small block-a few BBF) $5.00 each
Fan blade / water pump spacers $5.00 each
9) NOS 250 CI 6 cyl thermostat housing $ 5.00
10) Used Ford OEM coil brackets $5.00 each
11) One used electronic voltage regulator $5.00
12) Used 71' window cranks (loose black knobs) many more years use left $5.00 pair
13) Used PCV / valve cover 90% plastic elbow connectors $1.00 each
14) Used brass intake manifold vacuum "trees" (multiple port vacuum hose connectors) $5.00
15) 71' used windshield washer plastic tank (mounts on DS inner fender) $5.00
16) Ford OEM coil brackets $5.00 ea. (I have two/one single hole mount and one double hold mount both metal)
17) Dana 44 shim kit (for gear swap to get backlash set within specs) $5.00
18) Dual gas tank floor mounted valve/switch $5.00
19) SBF engine fan belts $5.00 for all three
20) 16 ea 9/16" RHT lugs / 66 ea 1/2" RHT stainless and chrome acorn lugs / 9 ea 9/16" X 2.75 RHT dually wheel studs / 23 ea 1/2" RHT black steel acorn lugs / 8 ea 9/16" X 3" LHT dually wheel studs / 31 ea 5/8" dually lugs $5.00 per "bunch"
21) Ford PS Saginaw pitman arm $25.00
22) New Champion (I have many other new sets-please ask) spark plugs $10.00
23) Ford SBF / C-4 aluminum transmission dowel $5.00
24) C-6 transmission filter with gaskets $5.00
25) Motorcraft 2150 carb rebuild kit, (complete except top bowel gasket-including a used one) $5.00
26) Wright brand 3/4" X 1" impact socket adapter $8.00
27) Sand blaster hood w tool, (tool needs suction hose easily acquired) $5.00
28) 3M respirator with new box of 3M prefilters / four new high capacity filters $15.00 SOLD
29) KD Tools engine ring compressor $8.00
30) KD tools engine hone (needs new stones easily acquired) $8.00
31) Ford TFI (80's Ford engines) module wrench $5.00
32) Ford & Chebby, (1/2" & 9/16") offset distributor wrench $5.00
33) Mr. Gasket engine degree wheel $5.00
34) Top post battery terminal puller $2.00
35) Nomex heat proof gloves, (think exhaust work) $10.00
36) D44 front axle wheel bearing socket, (I have two) $5.00 each
37) Ford/York AC compressor NOS shaft seal kit (most common place your AC will start leaking freon $10.00 pics coming
Thanks for looking guys and God Bless America and all of you!
Hello l am the guy that bought the windshield wiper switch from you over at Mtn Veiw at 153. Do you have the duel tank switch and the 3g alternator . If so let me know . thanks
- basketcase0302
PM sent."M-100"Hello l am the guy that bought the windshield wiper switch from you over at Mtn Veiw at 153. Do you have the duel tank switch and the 3g alternator . If so let me know . thanks
Good afternoon. A real nutcase stole my 71 F-100, and then used it to burglarize the Flagship Store of REI here in Seattle. He abandoned my truck with the full load of loot on the street. If I can figger out how to upload a photo, I will. The REI folks were happy to get my phone call, and came to my house to pick up the stuff. Their estimate of the value is about $6000. There's more to the story for later.
My problem is that when he ditched the truck, he took the ignition switch, keys, AND the bezel nut that secures the switch to the dashboard, so I couldn't drive my truck home. I found replacement switch/keys, but finding the nut to hold the whole set-up in the dashboard has stumped me. You don't, by chance, have one of those nuts that holds the switch, do you? This truck is older than the majority of people on this planet, and I'd like to keep it rolling and safe. 300 I6, homely but faithful. Best to you, Glen Moore glenamoore@netscape.net
- basketcase0302
Glenn I'm sorry but I don't have the bezel nut. It looks like there is also a spacer that mounts the switch? Heads up that you'll find an age old problem with changing just the switch most here hate, (you'll now have two different keys for the truck versus one). A recent post had a forum member here getting all three "cylinders" keyed alike from DC I believe?="gleno" Good afternoon. A real nutcase stole my 71 F-100, and then used it to burglarize the Flagship Store of REI here in Seattle. He abandoned my truck with the full load of loot on the street. If I can figger out how to upload a photo, I will. The REI folks were happy to get my phone call, and came to my house to pick up the stuff. Their estimate of the value is about $6000. There's more to the story for later.
Looks like NPD has the bezel though, ( I built almost my entire truck from NPD and most stuff they sell is really decent quality).
https://www.npdlink.com/search/products ... &year=1971
Jeff, I sent you an email requesting pictures, PM did not work for some reason. I am interested still, in the windshield washer tank.
