2nd owner 1969 F250 4x4 project
Show us your rides or projects!
Re: 2nd owner 1969 F250 4x4 project
Wow! Absolutely fantastic!
bellamor
Post by bellamor »
Woah, I can't wait to see how it will turn out.
Eric46
Post by Eric46 »
Nice job!
1970 F-250 4x4
Jbarnes79
Post by Jbarnes79 »
The project has been moving slowly until recently. Here are some updated photos of the progress so far.
http://fordification.com/forum/viewtopic.php?t=67810
1969 F250 4x4
1969 F250 Crew cab (Sold)
1972 F250
1969 & 1970 Mustang
Jbarnes79
Post by Jbarnes79 »
Well I'm happy to say she's FINALLY finished (for the most part) and now driving! My apologies for not keeping my posts up to date for those that have been following this build. I'll fill in the blanks as best I can with a few more posts and finish off with a short driving video.
1969 F250 4x4
1972 F250
1969 & 1970 Mustang
Jbarnes79
Post by Jbarnes79 »
The steering column was finally completed with all new internals including a new steering wheel. Getting the horn to work correctly was a major PITA! I felt kinda dumb when I realized loosening the column bolts under the dash allowed me to slide the assembly closer to the steering wheel to close the gap so the brush would make better contact instead of the other way around. :doh:
I decided to use the Willwood Combination valve to accompany the front disk conversion. It will allow me to always have maximum pressure to the front brakes while allowing me to dial in the pressure to the rear without locking up. It also has a switch integrated on it that I used to work the brake lights and deleted the pedal arm switch.
I welded up a mounting bracket and installed it next to the Master Cylinder so the adjustment is within easy reach.
1969 F250 4x4
1972 F250
1969 & 1970 Mustang
Jbarnes79
Post by Jbarnes79 »
At some point over the years with relocating twice, I lost some drivelines somehow. Also the front axle from the '78 caused the original driveline to be too long so a local shop made these for me and they turned out excellent!!
I don't have a photo of these being finished but I sprayed them with semi-gloss black engine enamel.
I decided to upgrade the dash pad to a sport version from TMI. The picture quality isn't the greatest because of the shop light. Hopefully you might be able to see the double stitching that matches the paint color.
1969 F250 4x4
1972 F250
1969 & 1970 Mustang
Jbarnes79
Post by Jbarnes79 »
Here she is completed. I'll post a short driving video in the video section.
1969 F250 4x4
1972 F250
1969 & 1970 Mustang
390FE1972
Post by 390FE1972 »
Great Job!!!!! 8)
Raiver
Post by Raiver »
Jbarnes79 wrote: Sun May 14, 2023 5:49 am Here she is completed. I'll post a short driving video in the video section.
That turns out really nice! Well done
Jbarnes79
Post by Jbarnes79 »
Raiver wrote: Wed Jan 24, 2024 10:21 pm
Thank you Raiver!
I've got a little surprise for it coming up that I'll post later......
1969 F250 4x4
1972 F250
1969 & 1970 Mustang
