PaPa's 69 F100 Explorer Coyote 10R80 swap
Venomous duck
Re: PaPa's 69 F100 Explorer
Post by Venomous duck »
I'm really happy with the results.
Venomous duck
This is the spacer that goes in the cross member behind the parking brake lever. I think the purpose of this may be to stiffen the cross member so the park brake does not cause it to flex.
Venomous duck
Parking brake lever
Venomous duck
Ft coil spring hardware
Wow! That is amazing. Great work! :clap:
Venomous duck
Thanks Randy, that means a lot. I will try to make regular updates. I have more progress to show.
hfdco4
Post by hfdco4 »
Thank you for posting those pics. Now I have something else to try. I love how the electrolysis works on rust, so now I have another step.
:fr: FE390PC
Venomous duck
Be warned, Zinc Plating is labor intensive and the learning curve is steep. However I find it very rewarding to take 50 year old hardware and make it look better than new. And with the chromate it will last much longer then just zinc alone. I would be happy to answer any questions you might have about the process. You are right, electrolysis is amazing. I used it on the spindles for this project. I just wish it could fill in the rust pits. If you haven't tried using graphite as your anode in your electrolysis tank then you should check it out. It's much cleaner, you don't get that rusty scum floating in your bath. I got mine at Mcmaster Carr item # 7979A19.
hfdco4
Post by hfdco4 »
Again thanks for the input and you can expect to see a message from me.
:fr: FE390PC
68RangoonRed250
Post by 68RangoonRed250 »
What kind of alchemy is this? :lol: Those results are awesome :thup:
1968 F250 2WD Farm & Ranch Special
hfdco4
Post by hfdco4 »
We are still working on making gold, but working on bump trucks is pretty close!
:fr: FE390PC
Venomous duck
Well I don't know anything about alchemy but I can sure make gold disappear!!
I have my frame partially assembled so I thought I would post some of the progress.
Venomous duck
The drum brakes are gone, and now are disc. I cleaned and re plated original king pin grease caps. They are a bit different then the aftermarket ones.
Last edited by Venomous duck on Fri Jun 26, 2020 9:09 pm, edited 2 times in total.
Venomous duck
The Springs, I beams, spindles and radius rods are all powder coated.
Venomous duck
It feels good to be going back together.Still a long way to go.
