strange carb set up. 1971 F100 AOD
So I just realized I have a 2 barrel carb from a 390 on a 302. Could running this cause any issues? I am looking to just replace the carb all together with a 2100 for a 302. Seems to run rich.
thanks
thanks
- basketcase0302
Re: strange carb set up. 1971 F100 AOD
You'll get 10 different answers on this question."BayStYAt"]So I just realized I have a 2 barrel carb from a 390 on a 302. Could running this cause any issues? I am looking to just replace the carb all together with a 2100 for a 302. Seems to run rich.
thanks
I ran the Motorcraft 2150, (best carb ever made as far as I'm concerned) from my 360 for a few years on my "little 302" (as some folks here call them) with no issues. Yeah it'll run rich but just go get the rebuild kit for the Motorcraft 2150 302 that has the smaller jet in it and call it a day.
Simplest / most dependable;e / easy to rebuild carb to date.
- Ranchero50
It won't run rich because the carb is designed to flow the correct amount of fuel for the CFM it's capable of. You just have a carb capable of flowing a larger amount of air. I run a 390 2100 on my 289 and it runs fine. Exhaust smells clean.
Thanks, It seems to have a lot of oil around the base and dripping onto the intake. What will cause oil to come from the carb?
How do I identify my carb? I can't find a model number.basketcase0302 wrote:You'll get 10 different answers on this question."BayStYAt"]So I just realized I have a 2 barrel carb from a 390 on a 302. Could running this cause any issues? I am looking to just replace the carb all together with a 2100 for a 302. Seems to run rich.
thanks![]()
the choke looks like jaws got a hold of it and the choke pull off is broken off completely. I only have 3 vacuum lines connected.
It is supposed to have a metal tag on one of the bowl screws.
Look on the sides for something like 1.08 or 1.12...
AOD? As in Automatic OverDrive transmission?
sorry no overdrive. Just AutomaticDuckRyder wrote:It is supposed to have a metal tag on one of the bowl screws.
- Ranchero50
Looks like a mid 70's emissions carb
crap! really...... Can an emissions carb cause running issues?Ranchero50 wrote:Looks like a mid 70's emissions carb
I am gonna replace it.
- Ranchero50
Not having the vacuum advance hooked up on the distributor will. What does the rest of the engine look like?
I have a Mallary Unilite Distributor. No vacuum advance on it. What to look for as for as rest of the engine?Ranchero50 wrote:Not having the vacuum advance hooked up on the distributor will. What does the rest of the engine look like?
what causes all the oil to build up around the carb ?
- Ranchero50
If I had to venture a guess I'd say a sick engine. Excessive blowby will work it's way up the fresh air intake for the PCV and foul that area. Of course a non working PCV system will too.
Pics of everything will help identify problem areas. No vacuum advance will limit drivability causing sluggish performance. Timing doesn't follow the load on the engine, only the RPM.
Ok,I will get some pics. Is the non vacuum advance Mallory distributor causing an issue?Ranchero50 wrote:If I had to venture a guess I'd say a sick engine. Excessive blowby will work it's way up the fresh air intake for the PCV and foul that area. Of course a non working PCV system will too.
Will a 2150 carb work on a engine that is 2100 carb pre smog with out electric choke?
The only replacement I can find is the 2150 at a good price.
thanks
thanks
