67 f250 help
67 f250 help
Hi I am a new subscriber. I have a 1967 Ford f-250 4x4, the other day I was coming home when I was driving up a steep hill the truck acted like the clutch was slipping "manual 4 speed" IE the motor was revving but had loss of power. I pushed in on the accelerator further and the truck came to a stop. The truck will no longer drive forward or backward, I am guessing the clutch went out. I am looking for feed back. As of right now the truck is stuck at the bottom of a 1 mile driveway in the snow. If it is a clutch replacement how difficult would it be under these circumstances? Thanks.
- Ranchero50
Re: 67 f250 help
Nothing goes well in the snow, especially a clutch job. I'd drag it to a garage and do it inside or at least tarp around it and use a salamander to heat it up. Done it more than once and while not pleasant, the heater makes it doable. Way too much misery with cold fingers on cold metal.
Re: 67 f250 help
Where is the clutch pedal when the clutch engages? If its starting to grab when the pedal is over halfway off the floor then you might be out of adjustment - it should start to engage with the pedal about 2 inches off the floor if adjusted right........
1997 Honda CBR 900RR
Re: 67 f250 help
It does sound like it's either gone or nearly so. I'd look at the linkage to see if there is any adjustment left in it--you might be able to nurse it to engage and drive it somewhere flat, warm and out of the snow.
I did a clutch on my '67 F250 in an unheated garage with a concrete floor in a cold January. I did have a space heater that made zero difference in the garage. I did the clutch in a day. Spent more time dicking around with a harbor freight transmission jack that was a waste of time than most anything else. Did spend about two hours with my son trying to get the trans aligned so she'd slip right back in place.
Clutch set at that point in time ( pressure plate, disc and throwout bearing with pilot bearing) was about $125.
or, money.
or, money.
Re: 67 f250 help
[quote="tsherry] Spent more time dicking around with a harbor freight transmission jack that was a waste of time than most anything else.[/quote]
I remember someone posting about using long bolts so they could slide the trans back instead of dropping the whole thing out - anyone remember where that was?........
Re: 67 f250 help
No, but that sounds pretty darned intriguing..
or, money.
or, money.
Re: 67 f250 help
It doesn't go forward or backward at all. I hadn't had a chance to adjust the linkage yet but I did look at it briefly. It looked to me like it was backed all the way out but I'll try. It's been snowing here and hard to get to. I did call to see what a new clutch would run $99.99-124. One place said there's 2 kinds a diaphragm and another i can't remember. I think they were referring to the cover? Iv never done a clutch before. I could use some helpful tips. I'm also looking for a manual.
Re: 67 f250 help
Try this thread:
http://www.fordification.com/forum/view ... hp?t=49099
They did not state, "remove the driveshaft" in the list, but that's required. Disassemble the u-bolts holding the joint together on the driveshaft that is between the rear of the trans and the center support (assuming that this is a two-piece driveshaft), and be careful not to lose the needle bearings in the U-joint unless you want to replace it at the same time.
Replacing the clutch isn't particularly challenging, aside from being on your back, getting pretty dirty, and getting the proper torque on things to loosen them up and reinstall them. I did my first clutch when I was 18 or so in a driveway with a 3/8" set of sockets and a handful of wrenches and a bottle jack.
I'm much better equipped now, 40 years later.
or, money.
or, money.
Re: 67 f250 help
You forgot the bottle of JD and box of Band-Aids......if you're anything like me those are requirements........tsherry wrote:
Jwguitar,
A diaphragm type clutch - has multiple levers around the pressure plate - will be easier on your leg because it pushes with less effort but I have always went with a lever or "finger" type - only has 3 large levers on the pressure plate - in my trucks because I believe they engage better even though they take a little more effort......my
Re: 67 f250 help
I start off with ibuprofen. Gentleman Jack is for when I'm done with it.
or, money.
or, money.
