New Clutch Noise when decelerate
mjmoog68
Post by mjmoog68 »
I appreciate the knowledge and experience on this site. Here is my problem.
I have a 68 Ford F100 2wd SWB 360 FE with a 3 Speed Ford Light Duty 3.03 Manual Transmission. Previous owner converted to 3 on the floor. I have done a complete rebuild of the engine and installed a new clutch as well.
I did my first test drive today and everything was going well while accelerating. However when in any gear and I take my foot off the gas and it starts to decelerate, I get these very loud high pitch squeal / grinding sound. When I press the clutch in it goes away and when I'm shifting it is smooth and sounds normal.
Does anyone have specific tests I should try to correctly identify the issue and does anyone have any ideas what the issue might be?
Thanks
mjmoog68
BobbyFord
Re: New Clutch Noise when decelerate
Post by BobbyFord »
That's going to be a driveline noise, not a clutch noise. With the clutch depressed you are stopping the input shaft of the trans from driving the rear wheels. What about rolling in neutral, noise gone?
I assume the gear oil level in the trans is correct?
mjmoog68
Post by mjmoog68 »
Yes the gear oil in the trans if filled up to the fill port. When in neutral and rolling there is no noise.
BobbyFord
Post by BobbyFord »
Is the rear differential full?
Whatever it is, you're looking for something under load on deceleration. I would check u-joints, axle bearings, mid-ship bearing (if applicable,) rear end gear oil level. Trans front bearings usually make noise in neutral and in gear. Rear trans bearing would usually make noise in 4th gear, under load.
mjmoog68
Post by mjmoog68 »
I put it on jacks and can see it now. I think you are right about the rear diff. When I let up on the gas, the drive shaft and the rear diff lurch up and make that noise. I will double check fluids and try again. Thanks for the advice.
BobbyFord
Post by BobbyFord »
mjmoog68 wrote:I put it on jacks and can see it now. I think you are right about the rear diff. When I let up on the gas, the drive shaft and the rear diff lurch up and make that noise. I will double check fluids and try again. Thanks for the advice.
Definitely check the u-joints. Not just for slop, but for grease. Grease the u-joints if they have grease fittings and take it out for a drive.
tnlprt
Post by tnlprt »
Sounds like a back lash problem in the rear end
radioactivelarry
Post by radioactivelarry »
While your at it take the drive line to a drive line service place and have it balanced and the U-Joints replaced. Should cost around 100 bucks or a little more with the joints, it is well worth the money. :thup:
Democracy is two Wolves and a Lamb voting on what to have for lunch. Liberty is a well armed Lamb.
Ben Franklin.
My Motto: I wish I had less to do, more time to do it in and got paid more for not getting it done.
:drive:
mjmoog68
Post by mjmoog68 »
Update ****
Found a local shop and had the transmission rebuilt. Looks brand new and drives great. I also put a new rear differential in and replaced the u-joints on the drive shaft. Runs great, shifts smooth, and nice and tight.
Thanks for all the advice.
Ranchero50
Post by Ranchero50 »
Did they find anything wrong?
