Clutch linkage
Clutch linkage
I just dropped my newer motor in and put a new clutch in while the motor is out. I am putting the linkages back together but the pedal wont tighten up. I fugured it would be hard to adjust since its new. but it wont even turn all the way out it just falls apart. I noticed the outer bracket on the frame can slide a little but i dont know. The bushings arent that bad and i havent installed the spring either. but i figured it would sit tight.
67 ford f100 custom /390 4spd
04 f150 RIP
1977 cb750ss
1976 kz650
2014 CB1100
2012 Forester
2019 Forester
04 f150 RIP
1977 cb750ss
1976 kz650
2014 CB1100
2012 Forester
2019 Forester
Re: Clutch linkage
Sounds like the rod is to short and you'll need to buy a new one. How long is the adjustment rod ?
Re: Clutch linkage
I disagree, it sounds to me like the pressure plate isn't set up correctly at the rebuilder or the factory. The height of the fingers is critical for linkage adjustment. The other possibility is that you have the wrong throw out bearing. This all assumes that everything is in correctly.
1967 F-100 4x4 custom cab.
Re: Clutch linkage
Clutch and bearing are identical. Do they make longer rods?
04 f150 RIP
1977 cb750ss
1976 kz650
2014 CB1100
2012 Forester
2019 Forester
04 f150 RIP
1977 cb750ss
1976 kz650
2014 CB1100
2012 Forester
2019 Forester
Re: Clutch linkage
Its got about 1/8 in of slack total. So I should be able to adjust it somewhere.
04 f150 RIP
1977 cb750ss
1976 kz650
2014 CB1100
2012 Forester
2019 Forester
04 f150 RIP
1977 cb750ss
1976 kz650
2014 CB1100
2012 Forester
2019 Forester
Re: Clutch linkage
Did you get the shifter fork and throw out bearing installed correctly?
Re: Clutch linkage
Ask yourself why the adjustment rod worked with the old clutch but not with the new one.
Re: Clutch linkage
Thats just it i dont remember how well it worked i just know it worked i blew the engine 5 years ago and it sat in a storage unit. Ive never done a linkage adjustment on it. It could be old parts not working aswell as they should. everything ive touched so far is new or refurbed. eveything ive replaced is put in correctly.
04 f150 RIP
1977 cb750ss
1976 kz650
2014 CB1100
2012 Forester
2019 Forester
04 f150 RIP
1977 cb750ss
1976 kz650
2014 CB1100
2012 Forester
2019 Forester
- robroy
Re: Clutch linkage
'evening Classic67,
Perhaps you'll find this thread interesting:
Short clutch release rod: how can I find/make a longer one?
Re: Clutch linkage
Thank you ive been trying to track a longer one down. Now i have a part number to go off of.
04 f150 RIP
1977 cb750ss
1976 kz650
2014 CB1100
2012 Forester
2019 Forester
04 f150 RIP
1977 cb750ss
1976 kz650
2014 CB1100
2012 Forester
2019 Forester
